Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
You need something sticky, able to glue plastic materials. Even contact cement should work if you set and center the dome while the glue is still wet.
Anyway, the piece won't be doing any force once installed. Check the glues you have at hand. Many glues could work. I wouldn't use an epoxy or cyanoacrylate, but general purpose glue of any kind should work.
How are those diaphragms working out for you? I too have a set of L112's and i have a duff 044 tweeter. Mannaged a repair previously on the other unit, by resoldering the hair folical that had become dettached. This time not so lucky....
Hi,
I have a spare non-working 044 I am going to repair eventually. I have done nothing with it yet. Likewise, I know there is some kind of seal inside you have to be careful with. I don't know if it is an o-ring type of seal or something else. I've been searching for info on it. Furthermore, I may have to take it apart to find out.
Well, I gave more info than you asked for. I'll get to it soon and get back with ya, but at least I have the domes. They are inexpensive, and took about 2-3 weeks to receive.
