NH-MAN
Addicted Member
Parked night before fine, start up next day its out.
Its never gone in or out before so no hint of bad connection.
Banged on dash nope slammed door a few times nope.
still out today
wiiggled wires in door jamb nope
tweeter that side works.
I never crank it and it doesn't get that loud anyway to even want to.
I have to take radio out at some point anyway to check as cd will not eject or play if under 80 deg.
I will take it apart soon just waiting on some new pins (just a little peg with a round ball on the end) for door panel as one or two broke when I replaced the door lock assembly (a year ago). I am also replacing the outer horizontal felt/rubber window trim/seal as its worn and just smears water when window goes up that bug's me while I'm in there checking the speaker/wiring.
called dealer confirmed no ext amp
only 60k on car
still out today
only 60k on car
before it would only work at one magical temperature of 80-85 or more at the deck itself cool it a couple degrees nothing so for last year maybe used it ten times when it was at its magical temp but would only maybe last 5-6 songs until its temp changed again then a wait for a magical day.
