loquatious
village elder
here's a question for you vintage 70s infinity guys. can anyone ID which model these vintage infinity 10" doped woofers would have originally come from?
i'm not clear on what mid-70s models used a doped 10" other than the column II. but, this is not the correct doped woofer for the column II, (which is only doped over the voice coil and uses a basket with only four supports). the magnets do look similar to those on the column II.
there is a pair, and 26974 is the same on both, and would seem to be the model number. the lower number is apparently a serial number, as one speaker says 2857548 and the other 2857549.
any light anyone can shed is appreciated.
