QSilver
As the title suggests, I've got a hum out the output of my pre-amp. It's a Pioneer C-90 paired with an M-90. I've rested the M-90 separately and its totally silent. When reconnecting to the C-90 I get a hum through the speakers.
When hooking a scope up to the output, I've got a small waveform, partly a square wave at 100Hz. It isn't effected by the volume control to I'm guessing the fault is after the volume control in the pre-amp?
Does the 100Hz point to a power supply issue? The unit has been recapped about a year ago and has done this on and off. Occasionally a light tap on the lid would stop it but I'd rather try to stop it happening in the first place. I've never dealt with 100Hz hum fault tracing so would appreciate some pointers or tips on what to try probing next to find it.
I'm in the UK so if your reading this in the US it would be 120Hz hum, double the line frequency. Oh, one other thing, the 100Hz waveform appears to be inverted between left and right.
Thanks for reading!
Thanks for reading!
