1040 Transistor Sub Source..?
mark long
I am making a substitute parts list for the 1040. Am interested in a good quick source for referencing transistors. Below is the oem stock list, i've also included a list of needed capacitors since i have it.
Transistors
2SA1015
2SA1084
2SA970
2SA998
2SA999
2SB560
2SB6464
2SB649
2SB737
2SC1815
2SC1959
2SC2240
2SC2300
2SC2320
2SC2500
2SC2546
2SC535
2SD438
2SD655
2SD666
2SD667
2SD669
2SD734
2SD786
CAPS
100v 0.47uf
100v 100uf
100v 1uf
100v 2.2uf
100v 220uf
100v 3.3uf
100v 470uf
100v 47uf
16v 470uf
25v 100uf
25v 220uf
50v 100uf
50v 10uf
50v 1uf
50v 33uf
50v 470uf
6.3v 470uf
63v 220uf
63v 4.7uf
63v 47uf
80 wvdc 15,000uf 105 celcius
B&D has all but the following in-stock
2SA1084
2SA998
2SB560
2SB6464
2SB737
2SC2300
2SC2320
2SC2546
2SD666
2SD669
2SD786
Here is a more recent spreadsheet with links to another source, ceitron, on far right column https://drive.google.com/file/d/1nDhIj_s7NgWVI_kmF2C1QXtsoAUElLBG/view?usp=sharing
you trying to go all original parts?
mostly, as much as i can without over investing. i actually only lack the following transistors at this point...prob sub them out to be honest but just to be clear i dont need to replace everything transistor wise, i just like to have backups but also because i have a second 1040 i'm restoring to sale.
2SA1084
2SA998
2SB6464
2SC2300
2SC2320
2SC2546
