Bradw764
Hi: I bought an 1180DC and it was damaged in shipping. I was able to repair the cosmetic damage ok. The filter board was jarred loose (which I didn't notice at first. I powered it on and it blew the main fuse. Found a shorted D427 output transistor. Ordered a couple of sets of outputs and some caps for the preamp board.
I removed the output amp completely from the unit and tested the pre-amp outs to a 1060 power amp in. Works great although I did end up soldering the filter board connections due to intermittent channel dropping out.
I hooked up the power amp again and left the output transistors out of the left channel and the right channel works fine.
I then swapped the outputs to what I thought were the left channel and disconnected right channel inputs and when I powered it on, I had left channel working but distorted. Then I lost the outputs. This time both a D427 and a B557. Also burned up a 3.3ohm resistor r786 on preamp board. Is there a good way to troubleshoot the power section? I am using a variac and current meter to watch for excessive current draw. Also the schematic I have is full of errors. Are the filter board or led peak board causing problems? Are they in the circuit when I'm using it as a preamp only? Thanks for any info. I have ordered more parts, hope to get them later this week.
