dd123
Does anybody know how to remove the cueing piston and cylinder in a Dual 1218? It is different than in a 1229. Mine needs to be refilled and I'd like to clean it before refilling. I got the tonearm lever and cueing lever disconnected underneath -- see photos. There's isn't quite enough clearance to get the knurled nut off the top of the cylinder after removing the 'C' ring. Even if I could get the knurled nut off, it don't seem like that would help because the cylinder isn't moving at all right now, up or down.
If it is a real pain to get the cylinder out, can I just refill without removal? If so, how? Thanks.
