Ben Rothman
Hi everyone, I have a Dual 1229Q turn table that has been working perfectly over the last couple of months. But as of last night the start/stop switch is getting stuck. What I mean by that is if i push the lever into the start postion the tonearm rises and it goes over to the record and drops down. After that happens the start/stop lever is supposed to go back to the middle. Mine is not doing that it is staying in the start postion and will not go back to the middle postion. When this happens I can here a sound as if the lever is trying to go back to the middle position but can't. If l lift the turntable up on an angle and press the start lever it does not get stuck after it drops the needle the start/stop lever returns to the middle position. If I take the record player off of the angle and put it down flat the start stop switch will work one more time and then if I do it again it gets stuck. If anyone here has had a similar issue or knows whats wrong with mine please let me know. I know alot of issues on these old duals are caused by dried up old greese and I know thats what a lot of people say to do so if you are going to tell me that please tell what parts exactly I need to clean and relube.
