125 Volt Fuses
S Phillips
Member
I picked up an old Sears by Fisher receiver that uses 125 volt 2 amp slo blo fuses for the speaker circuit and 125 volt 3 amp slo blo for the power circuit. The only fuses I can find on mouser and digikey or google search are 250 volt slo blo. Are these ok as a replacement?
My understanding is that if a fuse's voltage rating is = to or > than the specification, it is OK but do not deviate from the current (amp) rating.
Is the Slo-Blo specified for the speaker or is that's just what's there? Regular fuses are sometimes (often?) used for speaker protection. The time-delay will allow bass content but may not protect some tweeters.
I've used 20 amp fuses or shunted the fuse holder with a soldered wire to maximize the damping factor. Trust your ears: if it doesn't sound distorted the speakers are likely to be safe. I believe that back in the early days of Hi Fi, speakers were less robust.
Ignore the decimal point; it's probably a typo and they really want you to install a 20A fuse. :biggrin:
You could use that as a variable-damping feature, sometimes found on old tube amps. Compare different fuse values to determine if there's any change in sound quality.
:beerchug:
