jerrycpor
In the middle of a restore on this 140 amp and am trudging through the replacement of the single dual can with a pair Chemi-Cons.
I discovered a way to use the original ground strap, if it can be attached to the screw holding the rectifier to its heatsink. The screw is verified ground, and goes through the heatsink with enough protruding to fasten the strap to it using a star washer and nut.
I just want to double check that it can be safely tied to ground there without any issues??
Attached is are images with an arrow indicating where I'm thinking of tying into.
Jerry
Jerry
