Hi, I'm a bit confused. Can someone explain more clearly how this works? Does this mean you can run speakers wirelessly on different levels of your home?
How does the modification improve the device's function?
Thanks for your patience with a newbie!
Does the device support more than one component? Or is it just line in, speakers out?
I would like to be able to hook this up to my receiver to boost its power. Does this device have line in and out RCA jacks?
One set of input rca jacks in back to connect to one source (CD player, tuner or audio out from a computer).
It's useful as a utility amp to use with a computer, garage, bedroom system, video game system, etc.
Not sure it makes sense to connect to a receiver and your receiver would need preamplifier outputs to make it work.
It's popular because it's cheap and works fine as a small utility amp. It is not better than the amplifier section of most good receivers.
Cheers, Snade
