Not doubting what you hear, but comparing wires (especially in such a forum) must be done with some qualification. I don't doubt two different sizes (size alone) will produce different and possibly better results. However, without taking into consideration actual quality, one could very well diminish the quality of sound going from a good 14-ga up (in size) to a cheaper 12-ga.Recently, I wanted to replace my 16 gauge wire in my main setup. The reason, because I wanted something that laid down better, as the particular 16 gauge was sort of stiff.
I bought some 12 gauge wire from a car audio shop that looks to be of decent quality.
Anyway, when I first swapped it out I thought "man, my speakers seem a little more forward than before". I'm not a believer in speaker wire sounding different, but it sure seemed to. My amp has A/B outputs, so I put the old 16 gauge wire in the B outputs and simply A/B'd them a number of times. Guess what, it was all in my head, both wires sounded identical to me.
With that said, you may as well just get 16 gauge.
Here you go. Two gauge building wire. Is that thick enough, I wonder?
http://www.wireandcabletogo.com/2-A...dium=organic&gclid=CN7ijvvPi7QCFcXb4Aod4XAAIQ
It sure is cheap enough? lol
cnh2
Does any one know what guage a cat 5 cable is. with the wires summed up?
I ask because that is what im using on my MX 400. Have yet to hear a detriment. Ive got one cable split between the pos. and the neg. terminals.
They're both crap.
16 is maybe ok for lamps. 18 is good for nothing.
Just set your mind on 14 and be done with it. Don't be cheap.
Paul
Thanks to all who commented to my earlire post this morning about what gauge speaker wire I should get. I have decided, according to majority opinion, to go with 14 gauge wire. The problem now is that 14 gauge seems to be a lot harder to find for some reason.
Please let me know what brand of 14 gauge speaker wire would be good and also where I can locate it.
I went to my local Radio Shack and they do not carry 14 gauge wire at all.
I also checked Amazon for Monster Cable, which seems to get very good reviews and, while they have 16 gauge wire for sale on Amazon, I cannot find Monster Cable in 14 gauge on Amazon. And, when I do a google search of Monster 14 gauge wire, I cannot find much and what I find are very expensive wires.
I'd apprerciate any recommendations on what brand of 14 gauge wire would be best and where I can find it (my budget is in the $30 - $40 range, I guess).
I do not need much wire - about 20-30 feet would be fine.
Thanks,
Thanks,
