Jonas_Skaegg
Member
Hi guys!
I have a 170 DC I have been working on, on and off for 1 year or so. Used it some in between.
All caps changed, elcos and polypropylen at least. New speaker relay. new trimmer resistors for dc offset, new output transistors. The last thing I did now was changing the big filter cap to 2 15000 uF Nichicon Gold Tunes.
Quite many new resistors on both sides as well, making the bias match.
I also changed the 2 safety caps over the power switch (e version). I put in 0,01 uF 440VAC Film caps.
However, after a couple of days use working very well, I heard it made a frying sound when off. I discovered that it was the voltage selector on the back that had a bad connector and was arcing. It actually broke off inside when I started cleaning it. By changing from 220 to 240 volts I can bypass this bad connector and use of only good connectors for it. As I have around 238 Volts in my outlets It should be fine, But to my first question.
What happens with the voltage in my regulated supply, and how do I check and maybe adjust it? The secondary side of the transformer should see a voltage drop, right? I see no trimmer for it in this amplifier. The service manual doesnt mention it at all either, as it usually does for the marantz stuff I have been working on?
Also, when powered off I can measure dc offset over the speaker terminals, like a couple of hundred mV. Then when I power it on it goes to close to zero. Is this normal behavior? I measured now, after the amp has been shut off for 1 day, and I had 100 mV offset. Both sides do this.
Thanks!
Thanks!
