Hello guys,
I am trying to repair a Marantz 170DC with a bad left channel, when left on for a while R728, R729 and R731 along with Q710 would burn up. Other people have worked on this amp and replaced many parts without success, so it is now up to me...
Another post suggested to add heat sinks to transistors Q707, 708, 709, 710 as the equivalent run closer to their thermal limits. So I did replace all four transistor, added heat sinks and replace the 3 burned up resistors, however the resistors went into smoke the second I turned the amp on so there is obviously something else wrong. I cannot see any other damaged components apart the 3 resistors, any clues on what I should be looking for/replace?
Thanks for your help!
