jd3rdcoast
Have had this amp for a few years. Couple issues want to address:
1) Recently noticed right channel audio is distorting at higher output levels. Have swapped sides and follows right output plus remains when bypass 3250B preamp. Popped the cover and checked DC offset. Was 12mV R and -57 mV L. Set both without problem. Cleaned output pots w/D5.
Problem remains I see the R amp board has a partial recap.
Should I just recap the whole board and take it from there?
2) While doing above noticed the L channel is running much hotter than R side but sounds better. Primarily the two heatsinked transistors in middle of board are very hot to touch. Outputs are not hot. This board looks original. Anyone have any thought on the uneven heat issues?
