1940 RCA Victor Model 19K
steve1a
Hi what would be best way to unhook a rca magic loop antenna .to get the chassie out, 4 wires comeing out of loop 2 go to back terminal 2 go inside chassie, dosn,t look like any good spot to de solder the leads , didnt want to cut and he1788127769622.pngat shrink ,any help . 1940 RCA Victor Model 19K 1788127703150.png
The two small Rectangles that the wires go into unplug.
Take a flat headed screw driver and gently pry them away from the antenna.
Careful, They have not been moved for 70-80 years...
Thank you worked, changed the filter caps seems to have low tiney volume, have very weak 6f6 g tube ,would that cause weak volume very low,
