mfrench
Addicted Member
Hi Mike,
Absolutely gorgeous work, once again! Just love that terracing for the tonearm. You've become the preeminent builder in our expanding Lenco community. And Kudos for taking on the Admin tasks at Lenco Heaven! :thmbsp:
A couple of questions on this exciting build:
Did this older Bogen topplate have a shorter mounting distance (211mm?) than later Bogen/Prestos - i.e. B-61/B-69/B-70 (225mm)?
You identify the arm as a Jelco. Did Jelco build the Sumiko line which is what it sure looks like…. (What's the mounting distance?)
What cart is strapped to the "scratch" (Nuemark?) headshell?
And finally, with all that platter weight, have you been tempted to splurge on a new bearing upgrade?
All best,
Mario
Hi Mario,
I'm flattered by your kind words; and still humbled by your legacy at LH. I mostly just sit on my thumb there, and watch the good works of the other Admin over there. I'll eventually feel qualified to do something.
The mounting distance for this decks original arm is the same as the L70, I believe, though its been a long while since I looked it up, measured it. I'll have to measure it again.
The Jelco is similar to the Sumiko, and I do believe manufactured by Jelco.
Its the 12" arm, with a 290 p-to-s distance. Its also the same as the cherry arms by tonearmaudio.
The scratch headshell is a Stanton that I got to experiment with mounting an RPX/VRII on.
I was using it to try to get an idea of total length, and didn't want to mount a shell with a cartridge/stylus in it (didn't want to tear anything off). So I grabbed that for the stand-in.
Platter weight:
I'd love to get an aftermarket bearing for it, but, its not in the cards right now, until the economy turns around. I do have a Joels kit in it, with the hardened thrust plate, and have also installed a ruby ball bearing.
Its spinning records right now, and, it sounds fantastic, right off the finishing bench!
Thanks again, Mario, for everything!
