retrokid 52
Member
Hi Folks
Boy do I need some help
I am restoring a top of the line 1965 Zenith console model MM2670 with a 2G micro touch belt drive turntable.
I have done all the cleaning and greasing, new cartridge, and new belt.
I think the issue is that the fly wheel does not make contact with the idler wheel.
The placement of the idler wheel is between the motor stem and the fly wheel that has the drive belt on it.
When you place it in play mode, the idler wheel pushes against the motor stem but does meet the fly wheel that the belt is attached to and so no movement of the turntable. It almost seem that the tire on the idler wheel is just a bit too small. The rubber on the idler wheel is still pliable.
The turntable did not work when I got the console so I do not know if someone had replaced the idler wheel before and got the wrong size. The belt was not broker when replaced.
I have studied this thing for hours and can't figure it out.
Has anyone ever worked on this turntable and could offer some help?
Thanks
George :sigh:
Thanks
George :sigh:
