Moonwatcher
Hello, all. This Calrad tuner has been working perfectly, but suddenly the sound is cutting in and out and then completely out. It usually sounds great for five or ten minutes, then it just goes silent and the signal strength meter shows no life. Most all of the tubes seem to be lit, but I was wondering if there might be a likely culprit--a particular cap or tube, maybe. I notice there is one valve that may not be lit (circled in final photo).
Intermittently, a signal might come through for a second, then it goes quiet. Fiddling with the antenna connection sometimes leads to a couple of fleeting moments of static. I don’t know much about working with tubes (besides how to pay too much for them!). Photos are below.
Thank you so much for any thoughts you might have!
