1970s Diode identification help!
Ixlreight
Hi folks,
I am trying to identify this diode, please see images. It appears to have two green colour bands at one of the diode. It is in amplifier board bias/idle current circuit in a 1971 Hitachi SR700, schematic section included.
The receiver parts list, describes the diode as a HV-26G, same as on the schematic. Can't find any information about this online.
Other issue, idle/bias voltage on one side of amp is nearly impossible to adjust to other channel which Hitachi lists at 20mV plus/minus 2.5mV. The side in question can't go past 11mV. Swaped out differential transistors with no effect, caps were replaced. I suspect one of these old diodes are the issue.
If anyone has insights into these diodes, please share on the thread. I need specs on original to find a suitable match to replace. I could swap out but given their age and frailty, I don't want to chance desolder since the receiver does work.
Thanks,
I think they are "signal diodes" - such as 1N4148, 1N914, etc. Very common and sort of generic. I don't want to SWEAR TO IT (LOL), but I think you can trey a generic signal diode without risk of anything bad happening.
I can't swear by the NTE cross-reference search, but the HV-26G crosses to an NTE116, which is basically a 1N4005 general-purpose rectifier.
Check the forward voltage. If it's germanium it should be around 0.3V instead of 0.6V for a Si diode. I only say that because it kinda looks like a germanium diode but not exactly like the common 1N34 or 1N60.
HV-26 are single junction stabistor diodes made by Hitachi (forward voltage reference at 0.68V-0.75V at 30mA). Replacement could be 1N4148 according to the data I found. (see attached).
Some stil available on the auction site. No affiliation whatsoever with that.
