1980's Fisher (Sanyo) Integrated Amp indicator bulb
electronhick
Does anyone know a source for the 3mm diameter x 5mm length bulbs used on 1980's Fisher (Sanyo made) Integrated Amps?
I measured the power going to the bulb and it was 18VDC.
18V seems high, since many of the other receivers and amplifiers indicator bulbs are lower voltage.
It's probably 12V unregulated. I'd use a 12V 70 - 80mA or get an LED replacement from Joseph Mirabella.
