What if I'm listening to a CD on the solid state Marantz and it sounds a little too bright and fatiguing............... There's a YouTube video addressing this same topic but the person in the video only desired to use one source with each receiver (he liked one receiver for surround sound movies and the other receiver just for 2 channel CD listening - that's solved with a simple speaker switch).
But my amps do not have a pre out, they just have the standard aux, tape, phono, etc.
Guess it could be done with y-cables on the sources and one multi speaker box ..
Don't know if you can Y a turntable though .. not much drive there ..
For the line-level sources the y-cables would indeed work. Whereas the turntable would rather have to be run through either a switch first (for using the integrated phono stages of the Marantz and the Dynaco) or through an external phono stage first - 'cause otherwise the cartridge would "see" both phono inputs (as well as the cabling to these) as parallel loads, so that the load parameters would be wrong). However, in case of the second opton the problem would be, that the SCA-35 would only appear to sport three line-level inputs (Radio, Spare & Tape). While routing all sources through the Marantz and then going from its recourd output into the Dynaco would work, but most likely require the former to be powered for the purpose - so not quite optimal, either.
And switching the speaker outputs might also not be the greatest idea, given that the Dynaco is a tube amp, that probably doesn't like to be run without a speaker load. So H_87 would probably always have to remember to turn the Dynaco off, before switching the speakers over to the Marantz.
Greetings from Munich!
Manfred / lini
Hi everyone, I need your help in solving my problem. I have 2 integrated amps, a new Marantz PM 6007 and an old Dynaco SCA 35 tube amp. I have 1 pair of speakers. Right now I have everything hooked up to the Marantz: turntable, CD player, tuner and Bluetooth receiver. Question: is there a switch box or something that I can use that will allow me to switch between either amplifier while still being able to utilize all 4 sources mentioned above?? From what I've seen on YouTube videos and Amazon, there are speaker switch boxes that allow you to use 2 different amps, but you can only use a specific source off each amp, e.g. #1 amp has a CD player hooked up and #2 amp has a turntable hooked up. Is there some switch box available that will allow me to listen to the turntable on either one of those amps with a flick of a switch?
I should have studied harder and gone to MIT
