2 matched pairs or matched quad??
ferninando
Lunatic Member
so you have 2 channels with 2 PP tubes in each. Is it more impportant to have each pair matched or better to have all 4 matched as a quad??:scratch2:
Depends on how the output is biased.
If each output has it's own bias adjust, they don't necessarily need to be matched. In fact you can, by measuring, find tubes that are close to each other, in effect matching them yourself.
If each channel is manual adjust (single adjustment per side)then they need to be matched (pair) in that channel. Same if the amp is auto bias by channel.
If there is a single bias for all outputs then they all need to be matched to each other (quad).
Just for your own peace of mind if you get a matched quad you don't have to worry about keeping pairs togeather or where they go in the amp.
When I select output tubes for a fixed bias Fisher amp or receiver, I match pairs in the same channel. My rationale is that, in a push-pull pair, I want both sides of the excursion of the waveform on each channel to be able to go to the same or a similar amplitude before clipping.
I do my selection in circuit, with fully powered tubes and a 10 ohm resistor between cathode and ground. I check bias, swap tubes around, and then let it sit and check it again in half an hour. Some tubes, in particular the 7591, which I use a lot, can drift over time if they're getting bad. Observing that a tube drifts when under power for some time removes the tube from the queue and the next one is substituted in. I think Gordon W called it grid drift or something like that. Anyway, I am the beneficiary of his expertise on this subject.
I go by how the receiver is bias'ed. In pairs or all in one. Biased in Pairs, I would get Matched pairs, and mark them Left or Right. Biased all in one, I still mark them L & R but all so A & B. that way they always go back in the same socket they started out in.
Price wise matched quads are usually a buck or 2 cheaper.
Larry
