I don't understand your apparent surprise. As long as the copper doesn't oxidize or corrode from chemical reactions with air pollutants or other chemicals it comes in contact with, there is no reason for them to degrade.
Shelly_D
Lets be clear, skin effect only pays a part in high frequency transmission, well above the audio band. Megahertz, Gigahertz, definitely, Below 100 KHz, not so much.
Shelly_D
Your stance is clear, but then many people assert that there is no audible difference between different cables.
It's also been asserted that since all amps measure electrically the same, then all amps sound the same ..
I'm leaving all possibilities open, but stating that I clearly hear the differences between differing cables, and to my ear every amp sounds a bit different than another ..
The reasons why are an open question ..
You can believe what you like, skin effect and the migration of the current from full conductor cross section to the surface is a verifiable condition and the frequencies at which it occurs is well documented.
The skin effect of electrical conduction is established science, but the aural effects of the "skin effect" are debated ..
It's pretty clear that different wire coating materials can sound different, but repeatability is always in question, because of variations in our hearing acuity ..
Listen, and if it sounds better to you, well then it is better ..
You stated:
I was addressing your comments on skin effect. The effect of cables on sound is one that I have learned to steer well clear of. Whether or not I believe cables can effect what we hear is not an issue I will comment on. I do choose to correct misquoting of measurable and demostible science.
I know this is a old thread but I to use Kimber Kable, I use a pair of 8PR speaker cable
and it always sounds great!
This is the quote I referred to.
I call your attention to the phrase "...but the aural effects of the "skin effect" are debated...". At audio frequencies, skin effect is not a factor in the conduction of the signal from one device to another. If the phenomenon is not occuring during the signal transmission, it cannot affect the resulting sound quality.
That was the intent and meaning of my post. In that respect I do consider this a misquote. If you wish to read it differently then fine, do so. This is my last post on the issue.
