bloodlemons
Member
I am using a DB Systems DBP-6MC Resistive Loading Kit for the first time today with my Audio Technica AT-ART9 cart using an AT SUT with 200 ohms load plugs from the kit into Parks Audio Budgie set to 47K ohms like a typical MM input.
The AT-ART9 has a recommended load impedance of "min. 100 ohms."
I tried 100 ohms and 200 ohms and 200 sounds quite a bit better. In fact, at 200 ohms it sounds pretty GREAT. [Currently spinning "The Blue Mask," by Lou Reed; soundstage, clarity and dynamics are really impressive at this load.]
The problem I'm having is that the volume is greatly reduced with the 200 ohms plugs in the chain. I have to dime the volume to fill the room. This, of course, raises the noise floor. My integrated is a mid-60s HK A300 tube amp, so there's definitely some low-level white noise at this volume level. It's not that bad, but I'd prefer to eliminate it and have more useable volume.
Has anyone else experienced this type of situation? Am I doing something wrong with the loading kit?
