2020B phono issue
need2boat
2020B phono issue
I was hoping to get some help diagnosing a problem when I use the phone selection. I've tried 2 different record players and I'm getting intermittent noise and slight pops of varying loudness.
What I've tried so far:
changed speakers
Cleaned all RCA plugs and connections.
Changed out record player.
Checked ground at both record player and 2220B
I only get this when I use phono, it happens often but not always. If i lift the needle when its happening I will still hear it.
I'm new to vintage electronics but fairy handy so if this is over my head I do have some local repair shops in the South NJ area.
thanks
Joe
Both channels? Although it sounds like a transistor quitting on you, I'd start with replacing all electrolytic caps on the board.
