I have 2 MC 2205 amps. One is fine. The other not so. The amp appears to work find BUT when I turn it on the power guard NORMAL lights do not flash like my other amp does. Once the relay clicks the audio comes on and sounds great BUT the POWER GUARD LIGHTS do not light. Well sort of. As I said none of the PG lights flash at start up however the NORMAL lights do light up but very dimly compared to the other bulbs and compared to my other 2205. Obviously a very low voltage. The NORMAL switch IS in the NORMAL position. The LIMIT lights DO NOT light up either momentarily or otherwise. ALL bulbs are new. The sound does not appear to be limited or distorted. The amp sounds great. No distortion. The big problem is the NORMAL lights failing to light when everything is normal. Anybody here understand how to diagnose or repair this circuit? I make repairs all the time on other audio issues myself but not familiar with the McIntosh POWER GUARD system. I could use some help.
