Jamie Starr
Hey All: I recently did a minor restoration on a 2220. After cleaning it up, it sounded fine and I do not recall seeing anything unusual on the O-scope. I changed out the caps on the power board (P800), tone board (P500), amplifier board (P700), all 3 big caps (C004.C005,C006), all 4 pots on P700, and the output transistors.
I checked my work after each stage and did not see any shorts or distortion. I did not have any trouble setting "audio adjustments" per the manual.
During final testing, I noticed that the right channel on the scope was not tracking in-line with the left. No distortion on scope but it had less volume or power on the scope. I figured that it was close and could not hear much of a difference on my test speakers.
Once I connected 2220 to more substantial speakers, the difference in the channels was quit noticeable. Here are pics of what I am getting on the scope.
I have tapped around the boards and used freeze spray, but have been able to locate any problem. Any suggestions on how to troubleshoot this? Am I looking for a cap installed backwards? Loose wire? Transistor? Again, I don't think this was there before I worked on it, so I will take the blame. Thanks
I've got a 2220 with the same problem. Was like that when I bought it. Sounds good, just an output imbalance between channels.
