2220B Wrong Lamps?
jimmyboy1932
2220B. Lamps are marked STANLEY SP, 3V0.3A, S83
Too bad about your lamp holder. 8V 300ma are used for the meter/s. The lamps for the dial display should be 8V 200ma.
If you think you need a new lamp holder you could become a subscriber and thus put an ad in "Barter Town".
Good luck.
As long as you stick with an incandescent lamp you run the risk of having issues with the plastic...which is why LED's are such a good thing to use in the Marantz units that have that plastic bezel.
Thanks for the link. Did notice that it was tuned upside down, so you could not see that it had the same problem (not as bad)?
I think those are made by one of our AK members and they're brand new and custom made by model so I doubt the flip side has any issues. The 8v/200ma were the stock lamps according to the service manual if I cross referenced the lamp numbers correctly, not sure how you ended up with 300ma, Dave. :scratch2:
The one I was refering to, was the used ebay one.
