grey_beard
I have a 2226B that's new to me. It has low volume in both channels (and headphones) and distortion when the volume knob is turned up high (volume is still low through speakers and headphones).
I've cleaned the pots and switched best I could without taking the board out and there's no scratching or intermittency from any of the pots or switches with the exception of the Loudness button which I can't hear any difference with it engaged.
Routing input through Main In yields strong, clean audio. Output from Pre Out is quiet and distorts.
I've been able to do the bias and power supply adjustments on the Main Amp board with no issue so I'm lead to believe the issue is with the Tone/Pre board.
I have the service manual but I could use some help figuring out where I should begin tracing. I also have a decent meter and an oscilloscope.
Anyone with experience working on the tone/amp board have any tips to removing the board for service?
Thanks in advance.
Thanks in advance.
