bibota
Hello everyone,
I've no electronics background whatsoever other than the high school theory from 30-odd years ago. Many thanks to you all because literally all I know now I learned from you during the last 4 months, spending evenings on the forum.
So yes, got my 2230 and started reading. Of course, at first it felt like nauseating mumbo-jumbo but it slowly started to make sense. Limited sense, obviously.
At some point I felt confident enough for recapping. It started reasonably well with chassis, then P750 (even managed to do those without cutting any wires), P700, P400 and P800. I stopped for a good few hours of power and sound check after finishing each board and thought I was doing well. That is, until hitting P150 (found it very difficult on more than one account, but I'll skip that bit of the story to get to the point).
After having P150 done, there is a strong, low buzzing when inserting the first RCA into either Phono or Aux socket. The noise gets more or less cancelled when inserting the second RCA and there's reasonable signal for the speakers but the quality of the sound playing doesn't seem to be quite right even after that.
I went back and forth several times trying to find the problem but it seems I'm getting nowhere and have to admit defeat. I've also reached the stage when I'm not sure if a record sounds good or bad therefore don't trust my ears anymore.
So here I am, could someone help with some suggestions please.
