jackattack13
Member
Hi all,
I generally can find what I am looking for in this vast library of knowledge, but I am stumped at finding a replacement for C760 on my 2230 - P750 board. I was going through the board checking all of the components as it was popping fuses. Found a couple diodes bad, the output transistors, and C751. Decided to check the large film cap so I pulled it and ran it through my ESR tester. It came back "Bad" High ESR. It was reading 15.9 ohms.
Should I change this out? And if so, what would be a comparable component? I am not familiar spec'ing out new components that match vintage gear very well. Wanted to reach out to those with much more experience than me.
Thanks!
Thanks!
