I have a newly rebuilt 2230. It is a clean receiver and the rebuild went smoothly. Until distortion testing. The Total Harmonic Distortion measures high in both channels. The spec calls for <0.5% THD. This receiver exceeds that by the time it is putting out 2 volts per channel. At 15.5v (30w) it is hitting 1.6% THD.
After double-checking the bias and clipping settings, I tested to see if the distortion is on the "pre" or "main" side of the receiver. When the Pre Out jacks are fed to another amplifier, the distortion is not there. But if a pre amp is connected to the Main In jacks, the distortion appears. So it appears to be limited to the "main" side of this 2230.
I'm trying to understand why it is in both channels. Is there something the main amps share in common I should be looking at? The wire pair from the transformer, the rectifier, or the big capacitor? And of course I could have made identical mistakes on both main amps when rebuilding them. My posts here too often come down to some mistake I made. Heh.
Your suggestions will be appreciated.
-Randy
-Randy
