David_NC
I've got these two units and have a couple questions about recapping them.
The 2235B works fine. I replaced the lights in it years ago, and other than adjusting bias and offset and a Deoxit treatment, nothing has been needed. This receiver sounds great, but I'd like to ensure longevity and to see what replacing likely out of spec components does to improve the sound. I've found a couple cap lists online that have been very helpful, in terms of the electrolytics. How about the Mylar and ceramic caps? Are they usually OK? I know the basics about replacing the electrolytic caps, but I'm a bit unsure about the non polarized / other types. The main caps are 10KuF; do people generally up these or replace with the same value?
I've done a bit of work on the 1060, and it also sounds great with no issues just as it did before I worked on it. I replaced the big filter and coupling caps a bit over a year ago, and I also replaced all the electrolytics on the power supply board. The only thing that I noticed that seems odd is the action of the filters. When I engage the low filter, it's like every bit of bass and mid-bass is completely removed. According to the manual, the low filter's cut off should be 100Hz. Similarly, the high filter seems to remove every bit of high frequencies. Using both, it sounds like an AM radio - very compressed with next to no frequency range.
I see P300 (speaker and filter assembly) has four caps C301-302 (.047uF) and C303-304 (.0068uF) Mylar caps. Would these be the cause of this, or would it be more likely to be caused by the P400 (tone and pre-amp assembly)? That board has mostly electrolytics and a few Mylar and ceramics, too. Would these likely be the cause of the filters' behavior?
I'm ready to order parts but just need to know about some of the caps. Any pointers or suggestions as how to proceed will be greatly appreciated. Both of these units have great cosmetics, and I plan on keeping them, though they won't likely be in my main system.
