2235B Replacement DC Offset Trimmers?
absolve2525
Edit: These are the bias trimmers, not DC Offset. These 200 ohm wirewound black trimmers still work, except one channel is constantly .5mV higher than the other, regardless of how I fiddle with them. I'd like to get them closer matched. The recap kit I bought years ago included trimmers, but it's the wrong orientation. I can't adjust them from the top. Is there an easy way to add a resistor to balance these two out, or does someone have a trimmer suggestion that's still currently stocked? The pin orientation is upside down for the new trimmers I have. The outer pin is facing downwards versus upwards due to the four prong style of these old pots. Thanks!
