2240B how to confirm if transformer has failed?
runningdog
AK Subscriber
I have a 2240B that just died. I'm reading 3.5VAC off the two yellow wires going to the power supply from the transformer. The two orange wires from the transformer to the rectifier are showing about 2.0VAC. Both show infinite resistance.
The panel lamps light up. So the fuse and switch must be good.
Nnnnt. It turns out the switch was bad. The giveaway was that there was some voltage at the primary wires but not the 120VAC expected. Thank you John Wargo.
