kasbah512
Member
So after resolving some other issues, I'm now seeing -35V at J756. Here's the components I've tested so far and they all are functioning correctly: H002, H751, H752, H753, H755, H757, H759, H760, H761, H767
I'm not really sure where else to look, or if i should even bother checking the + side. I am getting the correct voltages at J753 & J761, and its not coming from a short in the protection circuit. The original issue was a failing open fuse from corrosion. not shorted, but it had very high resistance.
