petehall347
the brandy coffee man
power on .volts ..try dc volts first 200 setting then if very low reading change to 200mv dc setting
sorry i put the wrong numbers ..this schematic is hard to read the numbers .
should be r788 r789 ..
bias reading is a good idea
Put your meter on J754 to J760 and measure the bias- let us know what you get on the sick channel.
Are you able to pull and/or test Transistor H755?
i still think the problem is a resistor such as r760 10k r764 5.1k . r766 270 ohm r755 22k . etc
cant see any marked as fuse resistors though so i could be wrong .
