liam rtr
I am currently rebuilding my Marantz 2245, I did the power supply and tested the audio and everything was good, just a little noise, which I assume is because I haven’t yet biased the receiver. I started doing the P700, I put 22uf electrolytics in place of c703 and c704, I put 0.47uf 63v wima caps in place of c701 and c702. I replaced the electrolytic in the middle of the board with a 100uf 50v, and I replaced the two little sc458 transistors next to it with 992 transistors. I thought I should test the audio at that point and it was extremely distorted, I’m not sure what I should go back and check that could cause this.
