misterguitar
So I got a nice 2245. Its an early serial unit with the engraved face and everything. I pulled the phono board and decided to do a stem to stern rebuild. I gathered advice from the AK forum posts about caps and such. Decide to replace the trimmers, the caps, and all the old carbon comp resistors with new foil ones with tighter tolerances. Looks nice! But It doesn't work! Lesson learned.. Replace a few things at a time, test, replace a few more things. lol
It is getting 35 volts at 706. All the solder joints look good.I used Vishay Dale mil spec foil resistors. When they were available. I used I got a bunch of Toshiba SC2240BL transistors and used those to replace the H705 and H706. Caps where replaced . Used a Slimic 220 50v for C713. Used 47uf 50v for c703 and c704. Used WIMA 1uf 250v for C714,C715,C701,C702. All my subs sound ok I hope? Started poking around at the transistor voltages at 701 and 702. They seem off. I have kind of suspected that Mouser sent the wrong part for R734. It looked suspect. it was TINY compared to the other resistors. Maybe not enough wattage? I order it again just to see and they sent the same thing again.I measured the part with my meter. 100ohms. Just doesn;t look big enough wattage wise? Would that be a problem?
