Hi, here is an update. When I had jumped the wires to bypass the broken balance slider, I had gotten good sound from right channel, and no sound from the left.
Thanks to Bob (wlhd1610) who supplied the replacement slider, I slipped it into circuit. I however, I continued to get good sound on the right, and balance slider worked only on the right. Left was still silent. Also, tone mode on off was giving a loud ground hum.
Upon inspection, I saw a crack in one of the wafer circuit board of the tone mode switch assembly. This had put a gap on 3 of the circuit traces. Bob again offered to send me the correct part, but I managed to fix it myself.
I disassembled the parts holding the wafers, by unscrewing the nuts and sliding the shafts back. (carefully, there are tiny parts). I then unsoldered the legs and took the cracked board out. First I superglued the crack. Then I scratched off a small part of the protective layer to expose the copper trace on either side of the crack. Then applied Flux to it and tinned it with solder. I then soldered a lead wire across the gap for each trace. Then reassembled it and soldered the legs back on. Pictures attached.
Then turned the unit on, and viola! I had sound on both left and right channel
Good sound, no hum, no crackles. The balance slider worked perfectly too.
My issue is resolved! Thanks to Bob for your help! Now to continue on with soldering the balance slider in and recapping the rest of the unit, and I'm done!
