2250B FM Muting Issue
Davron94
Well-Known Member
I have what seems to be a unique issue with the FM muting button on a unit I'm currently working on. It seems that when the FM Muting button is engaged, all of FM radio goes out completely, even the strongest stations locked in stereo. I've checked the mute pot on the back of the unit first, cleaned it and found the ground strip was broken off, and the ground from RU04 and RU05 were not connecting to JU05> Deoxit on those and soldered the ground strip but those fixes and adjusting the pot with the mute button in did not fix the issue. Verified connection between P200 and P300 leads and I adjusted the meter to with L201 for centering on strong station and between stations. R363 or 362 do nothing to open the signal for strong stations.
Is there a common issue with this that can be checked? Where would I go from here to determine what is wrong and get it back to normal?
