Flip69
I recently replaced the dial lights on a 2252B with LEDs. The LED kit was advertised as suitable for the Marantz 22 series, with appropriate resistors built into the bulbs. The lights worked fine for a week or two. This morning, I turned on the unit. The lights lit for about a second, then went out. I replaced the fuses on the power board (one looked blown, I could not really tell with the other). That did not fix the problem. I found a thread posted by someone who had pretty much the same problem with a 2230B. The replies included suggestions on where to test on the power amp board, and the dial light board to troubleshoot the problem. I compared the 2230B schematic to the 2252B schematic to figure out where to run the same tests on the 2252B. I am not confident that I have the test points figured out for the 2252B. I don't want to start poking around unless/until I am sure where to put my probes. Can someone please help me figure out how to troubleshoot this problem? Thanks!
