2270 Differential Pair Transistors
I think if you are worried about failure prone - that notice must be 30 years old. So if they were going to fail - it would have happened by now.
Get it back together with the old transistors and enjoy!
If they blow later on - then worry.
charles
charles
That is my plan for now, and I am enjoying it as we speak!
Thanks airtime
I can confirm that ZTX795A does NOT work. I had the exact same problem as the OP: high pitched squealing sounds. Yes the pins were oriented correctly and yes, the HFE were matched.
I then ordered what was advertised as 2SA640 from Littlediode on Fleabay, matched HFE and installed... result was no sound from either channel - Nothing. Lights came on, fuse was okay.
Finally, I matched up 2 pair of 2SA992 from a big pile I had left over and installed those. Bingo! Works great.
My 2270 is dated 1975.8.9
Old thread, but hopefully this might help someone.
Exactly my experience as well. I hfe-matched my ZTX795A's perfectly, bent the legs around to the correct orientation and triple-checked my work before powering up on the DBT. No squealing, but no other function either.
I also ended up with KSA992's which worked beautifully - and they had the correct pin orientation to boot. My 2270 was an early-serialed champagne engraved unit, in the 4200's. :dunno:
Highhosilver seems to describing ossillation. Could the new components be "too good" or could they have been installed in a fashion that compromised the layout of the amplifier?
