rustyhusky
Member
Ok, I admit it. I'm a glutton for punishment. After rebuilding a 2265B, I'm taking on my cousins 2270.
The first thing I've noticed is that the older 2270 is much less service-friendly than the 2265B. Getting the two power amp board/heatsink assemblies out is nothing short of a $@&%!!!
A big advantage I had when working on the 2265B was the ability to create some "jumper cables" so I could work on and troubleshoot the power amplifier assembly outside of the chassis. I would like to do the same with the 2270, however the wiring harnesses are soldered directly to the boards.
Has anyone attempted to wire in some quick disconnects to the 2270 power amplifier boards using Molex or other similar connectors?
