Hello.
I've just received a Marantz 2270 from a friend with a known bad power switch band-aid solution.
I have removed that disaster and before I wire in a new switch (jumped brown/yellow switch wires) am assessing what else may be wrong.
On DBT - I am not seeing any dial lamps and relay is not clicking - I see what I feel are lower than expected voltages with a 100W bulb in DBT.
Here are the numbers - any help would be most appreciated!
VOLTS
AC in – 42vAC (Measuring Red Power wire and blue wire post fuse - fuse is good)
Orange wires from trans to DC Rectifier – 23vAC
Red and White out of Rectifier +/– 10.4 vDC
Green wires from transformer to lamp circuit – 2.2 vAC
Yellow wires from Transformer to Power Supply board - 23vAC
Transformer Ohms
Green/Lamp wires - 0.1 ohms
Orange/Rectifier Wires – 0.7 ohms
Yellow/Power Supply Wires – 10.9 ohms
VOLTS
Transformer Ohms
