Received this receiver as not working, explanation was it emitted smoke and power switch would not turn the unit off afterwards. That's about all I know.
Upon inspecting, I noticed the relay does not have its cover, and the board looks like it had an amateur do some soldering on the relay. I'd like to replace the relay before doing any testing, but was concerned if there are different relays for units that are based on the serial number, and if someone can provide a picture of the wires and where they go. I'm concerned whoever did this might have it hooked up wrong.
Towards the bottom of the 3rd picture, there is also what looks like a grounding terminal on one of the amp heat sinks that has a glob of solder on it, but nothing connected. Hoping someone can help with whether it's missing something there.
Thanks!
Steve G.
Thanks!
Steve G.
