gregmcm
Posting this as it might help anyone with a similar problem.
- left channel cutting out randomly
- Deoxit switches no change
- clean speaker relay no change
- Deoxit switches again no change
- replace speaker relay no change
- total fluke touch one of the pre-amp jack wires and left channel returns fine
- investigate pre-amp jack and notice there is some sort of spring mechanism inside that engages when a jack is plugged in
- Deoxit the jack and use an RCA jack to work the mechanism by plugging the jack in and out 10 times
- once the pre-amp jack is cleaned and working all good!!
