Thanks for the encouragement!
The PT01 switch assembly board is all passive components. The Low Filter and Hi Filter switches circuits are separate from the other switches on the board, except for a shared ground.
Here's the circuit, and here's what I've replaced:
The signal comes directly from the PE01 preamp board to JT01(right), JT02(left) and JT04(ground).
The signal leaves PE01 at JT05 (right), JT06 (left), and JT03 (ground)and goes directly to the Pre Out jacks.
I replaced the switch, the two .047uF caps CT01/CT02, and tested the resistors RT01/RT02.
I confirmed all the ground leads go to ground.
While the Low Filter switch is where the issue seems to be triggered, I don't think it is the circuit itself. There is no change when the Hi Filter switch is on or off. Suggestions welcomed.
