Perkinsman
"I've never met a fixer that I couldn't break"
Hi all,
I’m working on the 2275 & have a problem. I replaced the 3 caps on the right amp board, cleaned the old heat sink compound off the large transistors & replaced those plastic gaskets with new plastic & compound. I
also gently lifted those two driver transistors, cleaned & put new compound on them. When I powered on, I got very low volume & it was flubby from that channel. (It was working before.)Sound like something u may have come across?
